head gasket which one to buy???
Old Jun 2, 2004 | 07:18 PM
9seccivicsi's Avatar
Default head gasket which one to buy???
I am replacing my head gasket today and i was wondering which is the best head gasket to use????.. i am running like 28-30 psi and the block and head are not o ringed. I have used cometic the past 2 times and they havent lasted no more than 4000 miles.... is there a better gasket out on the market?
Old Jun 2, 2004 | 08:29 PM
vjace's Avatar
Default Re: head gasket which one to buy??? (30psiallday)
i would personaly use a honda gasket they do last very long time on other hondas
i hop i helped
peace
Old Jun 2, 2004 | 09:10 PM
Ti3d in's Avatar
Default Re: head gasket which one to buy??? (vjace)
Use OEM, and get it bored.
Old Jun 3, 2004 | 01:57 AM
b00sted93Hatch's Avatar
Default Re: head gasket which one to buy??? (Ti3d in)
Like the other guys said Factory. Been proven time and time again. Also copper spray both sides of the headgasket before you put it on.
Old Jun 3, 2004 | 08:56 AM
I have heard some bad things about using stock head gaskets ....... Has anyone tried the HKS head gasket and if so how many psi u running on it and was it worth the money
Old Jun 3, 2004 | 09:00 AM
Kataku2K3's Avatar
What have you heard about factory headgaskets? We only use GE overbored OE headgaskets and they've always worked great unlike Cometics we've tried in the past. Sorry can't help you much with HKS, we only use them on the Supra motor.
Old Jun 3, 2004 | 01:05 PM
X-Mazda 3 Racer's Avatar
Default Re: head gasket which one to buy??? (Kataku2K3)
We have found factory to work the best. Nothing beats OEM quality and reliability. With our gaskets, you can get them bored to any bore size, all 100% CNC cut and de-burred for unsurpassed performance.
Check them out here http://www.goldeneaglemfg.com/race_gasket.html
All of our dealers either have them in stock or can get them wintin a day or two.
Thanks guys for the good words on our gaskets!
Old Jun 3, 2004 | 08:53 PM
Default Re: head gasket which one to buy??? (GoldenEagleMfg.com)
Factory head gaskets are use on most Hod rod hondas I believe. Proven to hold over 30+psi. If you re-use a headgasket then maybe theres a problem.
new_climber
Honda Civic (2001 - 2005)
Aug 28, 2023 12:11 PM
da_33
Jan 11, 2007 11:12 AM
PhatBoy5015
Jun 19, 2006 12:44 PM
DLB1994
Feb 23, 2002 08:10 PM
