Having compression/sparking problems. Please help.
Old Sep 14, 2005 | 03:24 PM
iHOPEyouCHOKE's Avatar
* B A N N E D *
Default Having compression/sparking problems. Please help.
Like title says having compression.sparking problems. Did a compression test on my ls/vtec and it was 300 all the way across the board. Not sure why it's the high, but all cylinders are the same.
I pulled all the spark plugs, and all were black except for Cynlinder 3. It was white, and smelled badly of gas. The car starts, but it sounds like a WRX.
Some friends said, it could be an Injector stuck open, which is feeding the cynlider to much gas, which is causing it not to spark up, which will make it sound liek it's running on 3 cynliders.
The motor is also throwing a CEL, which is Code 8.
8 TDC - top dead centre sensor.
Please help, i'm trying to sell my car.
Old Sep 14, 2005 | 07:06 PM
slomofo's Avatar
GDD Member
White spark plug means running lean, too much gas will make it black.... I didn't read it all, just skimmed through, but there's your first tip.
Old Sep 14, 2005 | 07:36 PM
asubennett's Avatar
Default Re: (slomofo)
TDC sensor is your distriubutor. Try chaning that with a known working one and see if your problem is fixed.
Old Sep 15, 2005 | 07:57 AM
* B A N N E D *
Default Re: (asubennett)
i just replaced the tps..
Old Sep 15, 2005 | 09:01 AM
slomofo's Avatar
GDD Member
TPS - Throttle position sensor
TDC - Top Dead Center
Which one was bad?
Old Sep 15, 2005 | 09:35 AM
* B A N N E D *
my bad i read it wrong, the tdc is throwing a code. the tps went out last week and i fixed it.
Old Sep 16, 2005 | 09:41 PM
H22CivicS's Avatar
Default Re: Having compression/sparking problems. Please help. (iHOPEyouCHOKE)
Seems to me that you have symptoms that don't make sense together?
1) Possible clogged/faulty injector that's not shooting enough push water to fire that cylinder. (but you said the plug smelled badly of gas?)
2) Your distributor or distr. cap could be screwed. I fixed a LS a while back that had similiar problems. Pop off the distr. cap and take a look at the contacts inside it (where the rotor makes contact and transfers the spark). You may find that the contact for your troubled cylinder is F'd up. grab the rotor and see if there is <U>any</U> freeplay in it. Sometimes when the distributors start to wear out, the rotor actually wobbles as it turns.
(but if it wasn't getting spark to that plug, it shouldn't look like it's seeing a lean condition?)
3) Check (and then have somebody else check) your firing order...maybe you have two of them swapped and it's shooting fuel on the piston's downstroke.
(sometimes it's that simple and you're overthinking the problem)
4) Could be a faulty ecu...pop one of your buddy's ecus in there and try it...it's worth a shot.
There are only a few possible sources of the problem...it's either not enough fuel or not enough spark.
Also...make sure you only use NGK sparkplugs in a Honda. Bosch's, Delco's, etc. will cause an arc to develop in your plug wires. trust me on this one...I've fixed a ton of Honda's just by throwing in some $2 NGK's.
KeithDigital
Apr 4, 2009 04:02 PM
1crx2nv
May 10, 2006 08:13 PM
iHOPEyouCHOKE
Sep 15, 2005 09:46 AM
4inspeed
14
Oct 13, 2003 06:24 PM
zexteg
Jan 30, 2003 02:08 PM
