H22 Swap
I finally blew the original engine in my Del Sol.. Now thinking about swapping to a H22 i know it will be a tight fit and will need new mounts, but does anyone know of anything else i will need or problems i might run into with the swap?? I would like to do this swap but if it will cause tooo much trouble i might have to settle for a B16a swap instead
Thanks!!!
Thanks!!!
well the motor fits pretty good but youll have 2 little problems 1 is modify axles and 2 is open holes for the linkage but youll be very happy with the stock power, i got the alluminum billet mount kit for you,if you are interested letme know. good luck
