H22 conversion bellhousing to B16a tranny
What kind of info do you want,this is what I have found out.
I did a little research my self I tried doing it but the problem is the intermediate shaft,there is no way to bolt it to the block unless you make a custom bearing housing because the shaft is actually down by the oil pan instead of up behind the block and then still you would probably need a custom axle because of the plate thickness you have to make up that difference.You can just bolt a B-series flywheel to A H22 the problem is just the intermediate shaft.
Modified by dragline at 10:32 PM 3/31/2005
1slowcrx
Feb 27, 2015 05:06 PM
b16, b16a, bell, bellhousing, bellhousings, bolts, conversion, h22, h22a, honda, housing, installation, pattern, tranny, transmission
