Guages
Has anyone Used an Aftermarket Speedo and Tach in place of the Stock Guage Cluster. Meaning Totally eliminating the Stock Cluster, All Aftermarket guages. I have my CRX apart for the Winter and have the spare $$ and wouldn't mind trying it. Anyone done this? If so how did you do it?
Thanks
Mike
'88 CRX "ZC REX"
[Modified by 88ZC_REX, 1:21 AM 1/1/2003]
Thanks
Mike
'88 CRX "ZC REX"
I've seen it done. Basically make a plate to replace the stock cluster out of abs, carbon fiber, etc... and mount your gauges into that. I haven't seen any that retain the odometer though.
I have easy access to Carbon Fiber Sheets, I am more concerned about CELs that would follow as the Cluster isnt seeing the Speedo or Tach hooked up, or is this even a problem. I don't like Shift Lights or Aftermarket Tachs...Mounted elsewhere, Theft is a concern and with my guages in place of the Stock Cluster it wouldnt be something you would see at a glance.
Anybody done this?
Thanks,
Mike
Anybody done this?
Thanks,
Mike
