GSR oil cooler on LS
Old Sep 11, 2006 | 05:44 PM
tobe1424's Avatar
Default GSR oil cooler on LS
Can I gsr oil cooler be bolted onto an LS block...yes i know about that tube to run the coolant lines...but other than that is it like another one of them plug and play things that hondas have lol
Old Sep 11, 2006 | 11:20 PM
V-SPEC 1's Avatar
Default Re: GSR oil cooler on LS (tobe1424)
should be easy to do. Just drill and tap the block. Use those stock fittings on the GSR.
Old Sep 12, 2006 | 05:03 AM
tobe1424's Avatar
Default Re: GSR oil cooler on LS (V-SPEC 1)
I wouldnt see why you would have to drill and tap....
Old Sep 12, 2006 | 09:48 AM
havok hybrid's Avatar
take the water rail off the gsr and the sandwich cooler and hoses... and install them on the LS.. DONE!.
Old Sep 12, 2006 | 09:34 PM
V-SPEC 1's Avatar
Default Re: GSR oil cooler on LS (havok hybrid)
If you look really good on the back of the GSR/ITR, there's one hole/fitting called joint,that one of the oil cooler hose's goes to. The LS block don't have this joint. There's a spot on the LS block where you could drill it and tap it but I'm not sure what size tap it is.
Look at the part # 1. it's called joint, oil cooler.
Old Sep 14, 2006 | 05:08 AM
tobe1424's Avatar
but part #1 looks like a bolt that i can pull out with an adjustable and put back into my ls block....is all of this is a pain in the ***....Are there any good aftermarket oil coolers that are worth getting?
Old Sep 14, 2006 | 10:48 AM
IN VTEC's Avatar
You can tee it into the heater hose on the side of the head.
Old Sep 15, 2006 | 09:31 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: GSR oil cooler on LS (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">You can tee it into the heater hose on the side of the head.</TD></TR></TABLE>
it would be hard and frustrating to drill to the coolant jacket and tap a 3/4 barb in the proper location if the block is in the car. it's another story if the intake manifold is off and the motors out of the car.
sway892
Aug 6, 2005 05:20 PM
Huee
Apr 28, 2004 12:24 AM
ls_vtec_b18a1
Oct 23, 2002 09:22 PM
jdmhatch94
Apr 29, 2002 08:21 AM
