GSR Cams In A B16 Head
Old Oct 29, 2007 | 11:06 AM
ej1252's Avatar
Default GSR Cams In A B16 Head
Im about to throw in some GSR Cams on my B16 Head. Is it optional to do a valve adjustment or ill be fine to not do it and drive around????
Old Oct 29, 2007 | 11:10 AM
MR_FIX_IT's Avatar
Default Re: GSR Cams In A B16 Head (ej1252)
any time u disassemble & reassemble ur head u want to check ur clearances afterwards.....use a feeler gauge and check.....its always better to play it safe, especially when ur playing with a 400+ dollar head
Old Nov 5, 2007 | 03:18 AM
b18LS's Avatar
When you install the cams, arent you going to have to set all of your clearances, when you reinstall your rockers etc??
Old Nov 5, 2007 | 10:43 AM
ej1252's Avatar
Default Re: GSR Cams In A B16 Head (b18LS)
i think im just gon take it to the shop.
Old Nov 5, 2007 | 11:14 AM
-DC2-'s Avatar
the answer is absolutely, yes
if you can install cams, you can definitely do a valve adjustment. get the tool from amazon, it makes it much easier.
Old Nov 5, 2007 | 12:13 PM
ej1252's Avatar
Default Re: GSR Cams In A B16 Head (-DC2-)
ill probalu try that.
Old Nov 5, 2007 | 03:17 PM
Padawan's Avatar
Darth ModerVader
Why are you doing this in the first place?
Old Nov 5, 2007 | 06:30 PM
ej1252's Avatar
Default Re: GSR Cams In A B16 Head (Padawan)
get more power out of my B16.
Old Nov 5, 2007 | 06:37 PM
Padawan's Avatar
Darth ModerVader
The difference between the cams is not worth the time, effort, or expense. If anything, look to picking up a set of ITR cams instead.
Old Nov 5, 2007 | 07:08 PM
db1_jdm's Avatar
yup not much diffrence in the gsr cams and the b16 cams. not worth replacing them, and yes its absolutely necessary to adjust the valves after removing cams
Old Nov 5, 2007 | 10:34 PM
ej1252's Avatar
Default Re: GSR Cams In A B16 Head (db1_jdm)
oo i saw a 10-15 whp increase on some set-ups.
Old Nov 6, 2007 | 01:41 AM
-DC2-'s Avatar
with boost, yes. GSR cams make a lot more power.
Old Nov 6, 2007 | 08:52 AM
Racers edge tampa's Avatar
yes alway do vave adjustment itr cams are the way to go i have some for sale lmk if you want some better performance for the money .
Old Nov 6, 2007 | 10:53 AM
ej1252's Avatar
yes indeed
Old Nov 6, 2007 | 10:54 AM
ej1252's Avatar
Default Re: GSR Cams In A B16 Head (Racers edge tampa)
ok got it, aren't ITR cams better for N/A performance?? thats what i was told
Old Nov 7, 2007 | 01:23 AM
Katman's Avatar
well, in certain cases, upgrading to GSR cams can be a worthy upgrade, namely with the 1st B16A engines. 2nd B16 not such a worthy upgrade, but yes if sticking to OEM cams, CTR/ITR cams are the best performance cam you'll find for a B-series VTEC engine over GSR/B16 cams.
Yes TYpe-R cams are a great NA camshaft.
Old Nov 7, 2007 | 11:55 AM
ej1252's Avatar
Default Re: GSR Cams In A B16 Head (Katman)
cool, thanks for the info.
Old Dec 2, 2007 | 03:07 PM
racehesh's Avatar
Do you have to replace the cam journels also from b16s to gsr units? Or will b16s work with the gsr cams?
Old Dec 3, 2007 | 07:48 AM
tigueremalo's Avatar
Default Re: GSR Cams In A B16 Head (racehesh)
is the intake cam from the b16 bigger then the exhaust side cam from the gsr....?
LSEGHATCH
May 17, 2006 09:56 PM
Tuahe556c
Apr 18, 2006 10:00 AM
SOHCZCHatch
Nov 10, 2004 05:45 PM
93CXDRIVER
Jul 27, 2003 06:58 PM
