GSR bottom with B16 head
Old Sep 27, 2007 | 09:35 PM
CTM's Avatar
CTM
Default GSR bottom with B16 head
just wondering if this will give me any power what so ever..??? because couple friends told me it wont do anything just stay B16 straight... right now i have a straight 2 gen b16 and it does good... i just wanted to know if it will pull even harder if i do this poor mans type R.... just wanted to kknow your guys oppinion if it is worth it..???? if i should do it or not..
Old Sep 27, 2007 | 09:40 PM
doood's Avatar
been there done that
Default Re: GSR bottom with B16 head (CTM)
more displacement is always good
Old Sep 27, 2007 | 11:02 PM
92civicx's Avatar
if you have the money and you like working on cars - why not? it will give you more horses and torque from what i hear. Dyno it now and then after you put the block i'mn thinking about doing this also
Old Sep 28, 2007 | 02:57 AM
rd91sib18c5r's Avatar
I would go for it they say the compreshion will drop but not much,
would be great if your thinking of boosting it later.
Old Sep 28, 2007 | 03:04 AM
preludedriva's Avatar
im rockin the poor man R setup with CTR pistons :D im loving it
Old Sep 28, 2007 | 05:13 PM
posHonda's Avatar
Default Re: GSR bottom with B16 head (rd91sib18c5r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rd91sib18c5r &raquo;</TD></TR><TR><TD CLASS="quote">I would go for it they say the compreshion will drop but not much,
would be great if your thinking of boosting it later. </TD></TR></TABLE>
actually with the gsr block youd raise the compression using the b16 head. if you had a gsr than id say just stick with the gsr head but getting the gsr block over the b16 block is definitely an upgrade.
Old Sep 28, 2007 | 06:00 PM
sauceja's Avatar
Default Re: GSR bottom with B16 head (iVteC_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">
actually with the gsr block youd raise the compression using the b16 head. if you had a gsr than id say just stick with the gsr head but getting the gsr block over the b16 block is definitely an upgrade.</TD></TR></TABLE>
You have substantial proof of this? The combustion chambers of a PR3 head are bigger thus dropping compression by about 0.2
So if you have a 10.4:1 CR then it would go 10.2:1.
A gsr block and b16 with nothing else done is gonna be equivalent to a gsr no where near an R even poor R.
I spent alot of money rebuilding my gsr block to get higher compression and money on my R head to get better flow. Not worth it IMHO.
Just save up and get an H-motor.
Old Sep 29, 2007 | 10:08 AM
posHonda's Avatar
Default Re: GSR bottom with B16 head (sauceja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja &raquo;</TD></TR><TR><TD CLASS="quote">
Just save up and get an H-motor. </TD></TR></TABLE>`
My mistake I was thinking of PR3 pistons combined with a gsr head.
Old Sep 29, 2007 | 01:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">`
My mistake I was thinking of PR3 pistons combined with a gsr head.</TD></TR></TABLE>
my buddies rockin that same setup with rocket cams and hes milled the head too no piston slap
i got CTR pistons with b16 head s2s2 cams with 2 layer gasket running like a champ!
Old Sep 30, 2007 | 10:07 PM
EF_FEVER's Avatar
You will gain more low to mid range, more torque is alway good. You will have a better power band than with the b16. Also I would go with p30 piston to bring comp to about say 11.2. Get some CTR cams, with good tune and chip ecu, what ever I like or can get you hands on. You should put out some good number. I would rebuild the bottom end too.
Old Oct 1, 2007 | 08:42 PM
LastGenEK's Avatar
A gsr block and b16 with nothing else done is gonna be equivalent to a gsr no where near an R even poor R.</TD></TR></TABLE>
jdm_AE86
Nov 6, 2006 09:52 PM
Part1
Jul 11, 2006 06:55 AM
Surftouch
Jul 7, 2005 09:45 AM
eg4usdm
Feb 20, 2005 01:30 PM
LBR92DA-T
Dec 11, 2003 02:16 PM
