got fuel & spark. still no start
Old Aug 9, 2003 | 05:47 PM
Lo-Buck EF's Avatar
Default got fuel & spark. still no start
i have fuel and spark, but the car still won't start (91 civic with d15.) im not gettin any CEL lites either. the car cranks but doesnt start. any ideas? maybe a bad ground??
-spenc
Old Aug 9, 2003 | 06:29 PM
GSRswapandslow
Guest
Posts: n/a
wow....
g101 maybe?
Old Aug 9, 2003 | 08:05 PM
Lo-Buck EF's Avatar
Default Re: (GSRswapandbanned)
g101???? i have no idea what that is/means.
-spenc
Old Aug 9, 2003 | 08:20 PM
chictunner97ex's Avatar
Default Re: (Lo-Buck EF)
give us a past history run down of what you recently did to the car.
Old Aug 9, 2003 | 10:04 PM
untitled's Avatar
Default Re: (chictunner97ex)
timing belt could be of a couple of teeth.
Old Aug 10, 2003 | 03:51 AM
Lo-Buck EF's Avatar
Default Re: (88crx91integra)
car ran fine, but gear selector frok finally gave up at an autox. drove home (i live close to where the event was) and park it. i start it again to move it around the driveway to get it positioned well. no issues with starting. flash to this past friday when i finished the trans change. i knocked out the coolant temp sensor clip so the car didnt start. fixed that, cleared the ecu and still the car doesnt start. i can smell the fuel, we checked for spark and are getting spark. i didnt pull the engine, so the timing belt should not have moved.
-spenc
Old Aug 18, 2003 | 08:53 AM
Lo-Buck EF's Avatar
update. injectors ave power in run posittion, but not in crank and arent pulsing
Old Aug 22, 2003 | 05:40 AM
Lo-Buck EF's Avatar
Default Re: got fuel & spark. still no start (Lo-Buck EF)
turned out to be nothing. i gave up and trailor'd the car to the shop. they cleaned the plugs after crankin the car for a while, gave the sedt. a tap for good luck and she fired after a few more cranks.
GrnZ
Dec 31, 2008 07:55 AM
dc2doi
Jan 6, 2008 01:43 PM
vinuneuro
Oct 12, 2006 05:44 AM
boostinh22
May 6, 2006 05:02 PM
