Going all NA, some basic questions.....
Since my 95 Civic EX(d16z6, Auto) has 75600 miles on it, and I hate working 2 jobs. I have made the decision to go NA.
I already have an AEM CAI.
Next, this week I will be buying a Header, Im thinking DC Sports 4-2-1 or 4-1 SS. Any thoughts on Headers. I want the best for NA.
Then Exhaust. I could buy a catback kit, or should I just have a 2.5" exhaust custom made??? As far as a brand made Catback kit, what do you NA people think?
Next is Throttle body, P+P Intake Manifold, Head/valve work, Cam Shaft, Pulleys and finally Fuel rail/injectors and pump.
What order should I go about this all?
and finally, Is it worth it?? seriously
My plan is to make it running a little bit quicker (less bogged down) no racing of any sort.
Remember, Im looking for mid-range everyday driving power, not high end WOT stuff.
The most important answer I can give you is. NO its not worth it. Even after all those listed mods, you will still be auto which will also take a **** on you. My friend made the mistake of building a d series, supercharged with NOS. He could beat a gsr, but not if it was turbo'd or had NOS. You'll spend the same amount as a swap on a d-series to be competitive with a civic with just a swap, so NO its not.
Don't waste your money, it's not worth it. You will never be satisfied with it. Save your money, do a swap and have them convert it to 5spd.
I would definately just save the money you have now and put it towards a DOHC VTEC motor. You'll be much better off doing so. If you want something simple just drop a B16 for a lil more power maybe a GSR and if you really want to fly build a CRVTEC or something crazy. My friends CRVTEC in his 96 hatch ran 12.8@106 several weekends ago, it's all motor and only had the passenger and rear seats removed.
Thanks for the input and honesty.
Like I said, im not looking for racing but rather a stronger daily drive. I think the swap would be a perfect solution. Not only would I have a little more power, but also a 5 speed. I drive my AUTO like a manual and latley its been leaking...soooo, its time to go out and find a B16 motor. Thankfully I know someone here that has the ability to make this swap happen.
Thanks!
Thanks!
b18b auto swap would do it for you if you don't want to get that involved, but a 5spd is def the way to go....and imo worth it 110%
