glowing exhaust manifold?
Old Dec 11, 2003 | 08:21 AM
B_CRUZ!'s Avatar
Default glowing exhaust manifold?
what would cause a glowing exhaust manifold?
Old Dec 11, 2003 | 08:29 AM
doublejz's Avatar
Default Re: glowing exhaust manifold? (B Cruz)
a **** load of heat, duh
Old Dec 11, 2003 | 08:37 AM
B_CRUZ!'s Avatar
Default Re: glowing exhaust manifold? (doublejz)
lol... but why so much foo?
motor was rebuilt 6 months ago, and has a 3 month old catalytic convertor.
Old Dec 11, 2003 | 08:45 AM
Devlins 91LS's Avatar
Clogged cat, running REAL lean or REAL rich... or your ignition timing being retarded WAYYYYY too much
Old Dec 11, 2003 | 08:49 AM
B_CRUZ!'s Avatar
Default Re: glowing exhaust manifold? (Devlins 91LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devlins 91LS &raquo;</TD></TR><TR><TD CLASS="quote">Clogged cat, running REAL lean or REAL rich... or your ignition timing being retarded WAYYYYY too much</TD></TR></TABLE>
thanks... I'll check it out. o2 probably?
Old Dec 11, 2003 | 09:11 AM
JimBlake's Avatar
Ya mean like this?
Old Dec 11, 2003 | 09:24 AM
B_CRUZ!'s Avatar
Default Re: glowing exhaust manifold? (JimBlake)
yup.... but no snail.
Old Dec 11, 2003 | 10:47 AM
dip-set's Avatar
geezus thats what i call glowing..
Old Dec 11, 2003 | 11:00 AM
Philip's Avatar
I've never seen anything like that! How often does this sorta thing happen?
Old Dec 11, 2003 | 11:41 AM
D16OnTop's Avatar
dam ive seen some glowing manifolds but not like that
Old Dec 11, 2003 | 11:47 AM
sjg's Avatar
sjg
even with a good tune, run a turbo motor flat out for a half our and your manifold will turn a little orange.
Old Dec 11, 2003 | 12:02 PM
JimBlake's Avatar
Default Re: glowing exhaust manifold? (Philip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philip &raquo;</TD></TR><TR><TD CLASS="quote"> I've never seen anything like that! How often does this sorta thing happen?</TD></TR></TABLE>That's not my picture, so I don't really know the story. When I saw this thread it reminded me of it...
It's a Saab 900, mid-to-late '80s. It must be on an engine dynomometer. There's an empty flange face in the photo above the down pipe - that's where the right drive axle goes. So this is obviously not installed in a car. Besides, you'd see the fender, engine mount, & the firewall if it were in a car.
Probably getting off the topic. My posting that picture doesn't really help answer B Cruz's question. If it runs really rich you don't have air in the exhaust manifold to complete the combustion. Lean gives you higher exhaust temperatures, right? Besides, it has to run WOT for a while to get that hot.
So, B Cruz... Under what conditions does it glow? I kinda like the timing idea. Also what about valve timing?? Couldn't that do it too?
Old Dec 18, 2003 | 05:15 PM
Valve timing won't do it, it'll just bog
And running real rich is gonna pour hella fuel into the cylinders, not be lit, then go down the header where its ignited by the cat. So its igniting in the exhaust, not the cylinder. Thats why runnin real rich'll do it.
Basically, you're a/f is whacked or your ignition timing is.
Old Dec 20, 2003 | 05:38 AM
hondamanwill's Avatar
glogged somewhere
Old Dec 21, 2003 | 09:47 PM
Qfactor's Avatar
put it on a 5 gas analyzer and check your numbers, most likely running lean, which will show nox way up and O2 up.
Old Jun 4, 2004 | 03:52 AM
b20bvtec'd's Avatar
Default Re: glowing exhaust manifold? (b_cruz)
your intake cam is retarded check your timing at the cams.
Old Jun 13, 2004 | 09:02 PM
LuvNdaVtec's Avatar
Default Re: glowing exhaust manifold? (BDCruz)
Way To Much V-Tec action, with yo heavy-*** foot. Take it easy on the gas pedal.
jmeyer99
Honda Civic (2006 - 2015)
Dec 26, 2007 05:00 PM
crx18c1
Apr 17, 2007 11:37 PM
hondapwred95
Sep 5, 2005 06:35 PM
urbansi
May 9, 2005 08:51 AM
jaydm98
Sep 25, 2003 02:31 PM
