Gauge cluster indicator lights
For some odd reason, the following indicator lights DO NOT work:
- seat belt
- emergency brake
- low fuel
- THERE MAY BE OTHERS, I'M UNSURE...
Are all these connected in a way? I checked fuses and everything seemed fine. I can check again...
- seat belt
- emergency brake
- low fuel
Each one of those has there own little bulb/LED in the cluster. You may want to check those after you check all fuses related to said parts.
