fuse 14????
Old Sep 11, 2007 | 12:08 PM
nightkid619's Avatar
Default fuse 14????
i went and bought a 91 crx and the guy said it keep blowing fuse 14 what that fuse for? thanks for the help
Old Sep 11, 2007 | 12:44 PM
Relic1's Avatar
fuse #14 runs
Voltage Requlator (IG)
Emissions Control Solinoid Valves
PGM-FI Main Relay
PGM-FI ECU (IG1)
Fuel Pump
EACV
and it's a 10 amp fuse.
Old Sep 11, 2007 | 01:01 PM
Default Re: (Relic1)
so should i change all that or get a stronger fuse
Old Sep 11, 2007 | 03:15 PM
Relic1's Avatar
you should individually inspect each of those paths and try to determine which of them are pulling too much current.
upping the fuse value will only damage things further.
personally, I'd start unplugging everything on the that list and try a different fuse. If it pops it's a wiring issue, if it doesn't start plugging things in till it pops.
ThatOne02Accord
Jan 24, 2013 02:50 PM
nightkid619
Sep 11, 2007 01:19 PM
tuan...
Aug 7, 2004 05:47 AM
