Fuel pressure regulator question
Old Sep 22, 2011 | 07:25 PM
vtec25's Avatar
Default Fuel pressure regulator question
i just bought a Honda with 2 fuel pressure regulator with a aftermarket fuel rail. One FPR is adjustable and before the rail and the other is the oem one on the rail. The air hose is connected to the oem one and not the adjustable.
So my question is should i leave it like that or should i eliminate the oem one and move the adjustable one after the rail?
Old Sep 22, 2011 | 07:47 PM
FlewByU352's Avatar
Default Re: Fuel pressure regulator question
The vacuum hose allows the FPR to adjust the pressure based on RPM or throttle input IIRC. Running no vacuum and just seeing atmospheric pressure it reads a constant higher pressure. Connect it up.
Old Oct 13, 2011 | 10:53 PM
vtec25's Avatar
So should i buy a T fitting and split the air hose to feed both FPR or just switch the air hose to the aftermarket one before the fuel rail?
Old Oct 14, 2011 | 05:25 AM
grumblemarc's Avatar
The Grumpiest
Why are there 2? Pick one. Remove the other.
Old Oct 18, 2011 | 01:28 PM
207hondaguy's Avatar
Just run 1 after the rail.
90civicgsr
Aug 19, 2007 08:17 AM
Jayboy
May 1, 2005 07:42 PM
HmgLauj69
Aug 20, 2004 08:07 PM
lilxvtecxpwr
Dec 21, 2002 10:28 PM
