Fuel Pressure Regulator Instal-Need help
Old Nov 19, 2002 | 12:08 AM
StreetStyling's Avatar
Default Fuel Pressure Regulator Instal-Need help
Any one have links or imput on installing a Fuel Pressure Regulator? I have a 99' Integra LS non-vtech. Any hints would be a great help. Also, what pressure(lb/in) is recommended. Mainly street racing with the Intake and Exhaust Sys. complete is what I need it for. Thanks again!!!
Old Nov 19, 2002 | 05:08 AM
SpoonfedDC2's Avatar
Default Re: Fuel Pressure Regulator Instal-Need help (StreetStyling)
Um it very simple to install. Just 2 bolts on your intake manifold and loosen two hoses. Then install it vice-versa. Um i would run 35psi, but you might want a second opinion
Old Nov 19, 2002 | 05:34 AM
Desslok's Avatar
Default Re: Fuel Pressure Regulator Instal-Need help (SpoonfedDC2)
It should be just 2 bolts (10 mm), I'm not sure on your car, but on most it's on the driver side of the fuel rail. I would take a reading of what it is at right now and bump it up 2 lbs until you can get it dyno tuned. That's one of those things where every motor is different.
Old Nov 19, 2002 | 08:17 PM
Default Re: Fuel Pressure Regulator Instal-Need help (sp)
Thanks. I see how to do it now. As far as the actual pressure, what are the common rules? More pressure more power? I know its sounds very in experienced but I'm trying to learn. Any imput on that would be a great help. I bought an Arospeed FPR from http://www.StreetStyler.com . From the looks of it, its just as nice as the AEM
[Modified by StreetStyling, 5:20 AM 11/20/2002]
Old Nov 19, 2002 | 09:22 PM
Fuuma0083's Avatar
um.... well its not more fuel makes more power.... you need to set it to how much you need.
Old Nov 20, 2002 | 07:18 AM
Desslok's Avatar
Default Re: Fuel Pressure Regulator Instal-Need help (Fuuma0083)
As he said it is hard to do without a dyno. But if you have intake and exhaust, try bumping it up 2 lbs and see what your butt dyno feels.
Old Nov 20, 2002 | 07:50 AM
brcivic411's Avatar
make sure that the fuel system is not pressurized.. unless you like fuel spray all over the place!
Old Nov 20, 2002 | 09:17 AM
Desslok's Avatar
Default Re: Fuel Pressure Regulator Instal-Need help (brcivic411)
Usually when you put on the gauge, you put it where the service access bolt is, just put a rag around it and loosen it just enought to let the pressure out and the rag will soak it up.
Old Dec 1, 2002 | 02:12 PM
Its a 99 Integra LS(sorry for not writing it before). I did Get it off the rail but the instructions say to cut the top part off and install the neew on. Thanks again for your help
Old Dec 1, 2002 | 02:14 PM
Desslok's Avatar
Like this?
http://www.c-speedracing.com/howto/a...stablefpr.html
02 Civic SI 865
Dec 20, 2006 02:19 PM
StreetStyling
Dec 1, 2002 04:41 PM
