Fuel Pressure Issue ::HELP::
Old Jan 19, 2011 | 05:25 AM
1sl0weg89's Avatar
Default Fuel Pressure Issue ::HELP::
1992 Honda civic DX hatch B16a2 swap
Problem: I put the gauge on fuel filter this morning and on the TURN KEY im only getting 34psi no matter how many times I turn key and at IDLE its only reading 28psi and WOT is only jumps up to 34psi
Help please, Need to know what would cause this and what to do to fix this!!
NO BS HERE I GOT ENOUGH OF THAT ON MY HANDS
THANKS
Old Jan 20, 2011 | 10:19 AM
rollinswapshop's Avatar
Default Re: Fuel Pressure Issue ::HELP::
bad fuel pump or fuel filter or pressure regulator. it should be around 42 psi at idle and will rise as vacuum decreases
Old Jan 22, 2011 | 09:53 AM
HAMOTORSPORTS's Avatar
Are you testing this with the vacuum line to the FPR disconnected and plugged???
Element3488
12
Nov 19, 2012 08:53 AM
project91crxsi
Aug 27, 2009 03:32 PM
Psychoteen101
Jul 30, 2009 10:07 PM
Shmaa
Jul 7, 2006 04:59 PM
Tchleung
Oct 18, 2004 01:48 PM
