is this free hp website bull?
Old Feb 28, 2004 | 02:50 AM
h22-cx-guy's Avatar
Default is this free hp website bull?
i forgot how i stumbled upon this website but check it out. its suppose to be free hp mods that can be done to your car.
http://members.tripod.com/~Pre_ludE/pmods.html
are they good ways to get hp? how much hp are we looking at here?
Old Feb 28, 2004 | 08:42 AM
boostn420's Avatar
Default Re: is this free hp website bull? (h22-cx-guy)
you looking at 2 hp tops. This guy is nuts.
Old Feb 28, 2004 | 09:04 AM
mmuller's Avatar
Mad Scientist
Default Re: is this free hp website bull? (boostn420)
yeah, the fpr reg. mod. and the iab's mods are straight up stupid.
Old Feb 28, 2004 | 01:47 PM
ryanstev's Avatar
I love how he describes to advance your timing.
Old Feb 28, 2004 | 07:07 PM
Sliced Beard's Avatar
Default Re: (ryanstev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by retarded guy in idotic link &raquo;</TD></TR><TR><TD CLASS="quote"> Swaybar Mod
No, this isn't an engine mod. If you have lowered your car with lowering springs, remove the front swaybar. Honda puts a huge front swaybar on the cars to prevent oversteer, so millions of old ladies with no idea of how to control a sideways car won't wreck and sue Honda. The sway bar dramatically stiffens up the front end which reduces front wheel traction(ie. steering). More front traction means more steering. If you have more steering you can go faster into corners and still have the ability to turn. SO basically, your car will handle a ton better. On a stock car this also helps reduce body roll, that why I reccomend that you do it to a lowered car which has significantly less body roll than a stock height car. I removed the sway bar on a friend's stock height 94 Prelude and it had so much body roll it was scary at times. The car was a lot more unstable at high speeds also. However on my car(which had race springs) and Chris's 90Si(which has lowering springs/struts) the handling was improved a ton. So if you lowered your car, take the front sway bar and all the hardware off and throw it in a corner of your garage. Then take your car to an open track event or autocross and rail on it around a few corners and if you know how to drive, you will see a difference, big time. You have to push the car to it's limit to notice the difference. If you're a wuss and you don't push the car you won't notice anything. I took mine off and never put if back on. Around low speed sharp corners I've had my 92 totally sideways before, that's how much steering it has. To remove the swaybar you need to jack up the car, put it on jackstands and remove both front wheels. There are two 12mm bolts attatching the mounts to the car, then there are two 12mm nuts attatching the swaybar to the front suspension. There won't be any tension on the bar and it pulls out over the exhaust downpipe. </TD></TR></TABLE>
this has to be the dumbest thing i have ever heard
Old Feb 28, 2004 | 08:31 PM
thehondaguru's Avatar
Default Re: (dirtyd463)
DUMBEST **** EVER. ALL THOSE ARE JUST DUMB MODS
Old Feb 29, 2004 | 12:19 PM
Xsi's Avatar
Xsi
Didn't know throwing away dush shields was a mod
Old Feb 29, 2004 | 12:35 PM
blah13's Avatar
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">Didn't know throwing away dush shields was a mod</TD></TR></TABLE>
Dude, its like an extra .3 in the 1/4, less drag, duh.
Old Feb 29, 2004 | 12:43 PM
StyleTEG's Avatar
Default Re: (Xsi)
Its different than stock, so technically wouldn't you be modifying?
You can get better brake cooling by removing the Shields (which can be a restriction of airflow). Wouldn't really be worth doing unless you do track events or wheel to wheel, but I know lots of people who have done it with good results.
Old Mar 1, 2004 | 12:30 PM
h22-cx-guy's Avatar
Default Re: (StyleTEG)
i was planning to do t he dust shield mod. but what bout the rest?
Old Mar 1, 2004 | 01:13 PM
Xsi's Avatar
Xsi
Timing advancing can help but only go 1 or 2 degrees and get it done properly. The coolant bypass mod can also help, especially in conjunction with other heat reducing mods like hondata IM gasket and heat a wrapped header
Old Mar 2, 2004 | 12:41 PM
h22-cx-guy's Avatar
Default Re: (Xsi)
how does the cooolant mod help in conjucntion with the hondata IM gasket and wrapped header?
Old Mar 2, 2004 | 01:13 PM
GreenEX's Avatar
Default Re: (h22-cx-guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22-cx-guy &raquo;</TD></TR><TR><TD CLASS="quote">how does the cooolant mod help in conjucntion with the hondata IM gasket and wrapped header?</TD></TR></TABLE>
the im gasket keeps the IM cooler and wraping the header keep the engine bay a little cooler so u dont suck in warm air
Old Mar 2, 2004 | 02:02 PM
Xsi's Avatar
Xsi
I just meant that together they will reduce intake temperatures a lot more than if you just do one
Miracle
Honda Civic (2001 - 2005)
25
May 30, 2006 07:28 PM
igo4bmx
Jan 8, 2005 09:32 PM
infamousR13
Honda S2000
16
Nov 30, 2003 01:23 PM
ddua
Jul 22, 2003 07:59 PM
