First B18 EK project
Hi guys I'm new to the Honda world and currently building my own. I was wondering if anyone had pics or part number of the OEM engine mounts I would need for a B18A1 swap in a 97 cx. Also if Ebay radiator hose kits would fit the stock (97 civic cx) radiator I have. thamks!
this is for the hose kit
http://www.ebay.ca/itm/350662681086?...84.m1423.l2648
http://www.hasport.com
http://samcosport.com
Both websites have all the parts you need for your swap, I understand they are pricey but anything worth doing is worth doing right. If you insist on using used parts try ebay for the used hasport mounts (not something I would do personally) or if you were trying to use OEM you would want the mounts from a 99-2000 SI. Again, I stress anything worth doing is worth doing right. I've personally used the swap parts from both companies on my B18A CRX (along with the HasPort shift linkage). Good Luck.
Find yourself EM1 rear and drivers side mounts.
Bigger challenge is going to be wiring: https://honda-tech.com/forums/hybrid-engine-swaps-18/gathering-ek-wiring-information-558245/
You can use the stock radiator, but you need Integra hoses and they're larger than than the Civic inlet/outlet. Just be sure to re-tighten after warm-up and continually check them.
luvmihatch
Mar 14, 2012 08:33 AM
seeeya04
Oct 22, 2005 07:18 AM
