Final Drive Question... 4.4 in 5spd & 4.765 in 6spd...
Old Feb 8, 2006 | 03:34 PM
JRSC EM1's Avatar
Default Final Drive Question... 4.4 in 5spd & 4.765 in 6spd...
I own a 2000 Civic Si and I know the final drive is 4.4:1 with a 5 speed trans.
I looked online and saw that the 2006 Si's have a 4.765 with a 6 speed trans.
Now my question is if I am in 5th gear at 80 mph in my 00 Si and the 06 Civic Si is in 6th gear at 80 mph what is the difference in RPM going to be? Will my cars RPM be higher even though the final drive is longer? Will the RPM in the 06 Si be lower?
Thanks in advance, your help is greatly appreciated!
James
Old Feb 8, 2006 | 09:36 PM
JRSC EM1's Avatar
Default Re: Final Drive Question... 4.4 in 5spd & 4.765 in 6spd... (JRSC EM1)
Anybody?
Old Feb 8, 2006 | 11:52 PM
No_Fear's Avatar
i thought you wanted to put kseries gear ration in bseries
do you know 06 Si ratios?
Modified by No_Fear at 6:23 PM 2/9/2006
Old Feb 9, 2006 | 05:45 AM
dognutz's Avatar
Default Re: (No_Fear)
I think the ratio is drive shaft turns: wheel turns. so 4.4:1 drive shft turns to 1 turn of the wheel vs. 4.76:1 If this is correct then the closer you get to 1:1 the lower the rpm will be at a certain speed. I don't know if this is correct , can somebody else chime in.
DirtAccord
Nov 17, 2018 04:57 PM
ribal_gh
Honda Civic (2006 - 2015)
Jul 29, 2017 07:52 AM
L8ApexH22
Jun 29, 2005 07:49 AM
RS_91
Aug 27, 2003 07:31 AM
powerfulperformance
Aug 11, 2001 03:08 PM
