Ferrea Beehive Valve Springs...NOT HAPPY!!!
1 Attachment(s)
Ended up using the springs in my 84x87 gsr with pro2 cams. Did proper Break-in and Ended up breaking the cylinder #2 Intake spring. Valve fell into the cylinder, put a hole in my piston, and crushed the head. Would advise anyone looking into these springs to do research first, wish I went with the dual springs instead to save me this hassle.
P.S. The motor had less than 500 miles and it. broke the day after my tune was done.... |
Re: Ferrea Beehive Valve Springs...NOT HAPPY!!!
And what was your motivation in going with these in the beginning?
My engine builder recommended them. He never had any issues with them, even running tolerances 6 times tighter than mine were set at.
Have you contacted Ferrea about this? Might be a long shot...but maybe they would compensate you somewhat for the part failing?
The shop already contacted Ferrea with disappointment.. They will treat him good since he's an authorized dealer, and mainly uses their products. Ferrea said to send the valvetrain back and they will analyze it to find the source of failure. It broke on the coil right under the retainer, a very unusual spot. I'll have pics posted tomorrow.
Wasn't Ferrea's fault...I should have researced before he used them. The beehives Max Recommended Lift is 12.7mm. The Pro2 Intake lift is 12.8mm. No wonder why it failed :cry:
that sucks....but ferreas are the best...even at 12.7mm u were pushing them hard...u should always have room for expansion
Originally Posted by cibao2ner
(Post 46571817)
that still sucks I hope that the engine builder is going to help you out some since he wanted to recommend them and built the motor when he should have known as well? Hope it works out for you were you aren't just getting screwed though. Good Luck
Dropping a valve is everyone's worst nightmare. Good luck getting this sorted.
yeah or snapping a timing belt which really has the same bad effect
Originally Posted by HCivExoo
(Post 46572611)
What a way to ruin a $7k motor :cry: |
Originally Posted by rich7777
(Post 46572629)
Originally Posted by DA93teg87
(Post 46571775)
Originally Posted by Uncle Dave
(Post 46574316)
So did the shop know what lift the cams had ? so your thread title is misleading as IT WAS NOT FERREA's fault maybe now you should correct the title to say YOU AND THE MACHINE SHOP stuffed up.
well either I hope it turns out for the best for ya, even if it was Ferrea for whatever reason I don't think the original poster is trying to say that all Ferrea parts are bad or anything. Perhaps just a bad set if that's even the case which it may not be.
(Post 46575861)
Hope so keep us updated when you back from Ferrea
1 Attachment(s)
Little bit more carnage.
thats an unhappy valve!
(Post 46577797)
Update!! Got the motor to the shop and taken apart. Needless to say I got lucky! Will have pics posted tomorrow. Hopefully pull the sprigs out and pressure test them next week before we send them off to ferrea.
Good stuff, looking forward to the updates
(Post 46577074)
Basically we had .006" room to work with, and that was at 0 lash.
You should have had more like .060" clearance, not .006". |
Originally Posted by EG1834
(Post 46764759)
What were the installed heights and coilbind heights?
