explain gear ratios pleeze
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 »</TD></TR><TR><TD CLASS="quote">Hey can anyone explain to me how gear ratio's work?
. Such as what does adding a 4.9 final drive. -Thanks</TD></TR></TABLE>
well if you want a quick and dirty explanation,
longer gearing = wack acceleration but great top end speeds
shorter gearing = wack top end speeds but great acceleration
there is a middle ground though, if you mix the right gears.
The final drive is like a filter that each gear has to go through, and when you increase or decrease the fd ratio the gearing is increased or decreased as well. A final drive increase will help increase acceleration for all 1-5 gears as a whole.
its like riding a 10speed bike...
when you change to a lower gear its way easier to pedal, which gives you faster acceleration, but when you've maxed out the gear your top end speed is hampered. When you put it in a higher gear it becomes harder to pedal, but as soon as you get going you're haulin *** in top end speeds.
hth
. Such as what does adding a 4.9 final drive. -Thanks</TD></TR></TABLE>well if you want a quick and dirty explanation,
hth
slofu
Sep 4, 2002 02:05 PM
