Evap control selenoid
I have erick's racing throttle body but there is no place to hook up the hose that goes from the old throttle body to evap contorl selenoid on the erick's throttle body. on the stock throttle body there ar three tiny holes that lead up to the fitting, which has a large diameter on the top and a pin hole in the inside part of it. the red hose is the line i need to find a place to connect. will i be ok just to hook it to an extra vacuum fitting on the intake manifold or should i put it before the throttle body?
