ERR!! MISFIRING ALL CYLIDERS.
Old Sep 10, 2006 | 09:15 PM
GoldenEGG's Avatar
Default ERR!! MISFIRING ALL CYLIDERS.
Hey guys so can anyone list down reasons why a motor misfire all cylinders?
I have an LS 84mm block on a GSR head running boost
Old Sep 11, 2006 | 05:38 AM
Lewdin' Incognito's Avatar
Default Re: ERR!! MISFIRING ALL CYLIDERS. (GoldenEGG)
Plug wires hooked up wrong?
Old Sep 11, 2006 | 12:19 PM
unknown0001's Avatar
What kind spark plugs/wires do you have? do you have your plugs hooked up onto the distributor properly?
Old Sep 11, 2006 | 12:22 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ERR!! MISFIRING ALL CYLIDERS. (Mr.RHTuner)
They have to be hooked up wrong. Verify your plug wires and distributor settings.
Old Sep 11, 2006 | 02:54 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: ERR!! MISFIRING ALL CYLIDERS. (JDM_Ej)
A bad coil pack could be a possibility.
Old Sep 11, 2006 | 06:40 PM
GoldenEGG's Avatar
Default Re: ERR!! MISFIRING ALL CYLIDERS. (ActiveAero)
yep i got the wires on correct, I got the Nology hotwires the wires that has ground wire on them. Im running a brand new MSD SCI, new rotor, new Blaster2 (although i droped it once), I got NGK Cold Plugs.
Could it be the timing? The marks are lined up but didnt use a timing gun yet.
Thanks for your help guys . Cant wait to bring this bastard out and haul ***.
Old Sep 11, 2006 | 07:31 PM
Jim Truett's Avatar
If it were me I would toss all of that **** in the trash. Get a set of NGK blue or OEM plug wires and a known good, unmolested distributor.
taken from: http://www.magnecor.com/magnecor1/truth.htm
"CAPACITOR" EFFECT WIRES" with grounded metal braiding over jacket
The most notable of exaggerated claims for ignition wires are made by Nology, a recent manufacturer of ignition wires promoted as "the only spark plug wires with built-in capacitor." Nology's "HotWires" (called "Plasma Leads" in the UK) consist of unsuppressed solid metal or spiral conductor ignition wires over which braided metal sleeves are partially fitted. The braided metal sleeves are grounded via straps formed from part of the braiding. Insulating covers are fitted over the braided metal sleeves. These wires are well constructed. For whatever reason, Nology specifies that non-resistor spark plugs need to be used with their "HotWires." In a demonstration, the use of resistor plugs nullifies the visual effect of the brighter spark.
Ignition wires with grounded braided metal sleeves over the cable have come and gone all over the world for (at least) the last 30 years, and similar wires were used over 20 years ago by a few car makers to solve cross-firing problems on early fuel injected engines and RFI problems on fiberglass bodied cars — only to find other problems were created. The recent Circle Track Magazine (USA, May, 1996 issue) test showed Nology "HotWires" produced no additional horsepower (the test actually showed a 10 horsepower decrease when compared to stock carbon conductor wires).
The perceived effect a brighter spark, conducted by an ignition wire, encased or partially encased in a braided metal sleeve (shield) grounded to the engine, jumping across a huge free-air gap (which bears no relationship to the spark needed to fire the variable air/fuel mixture under pressure in a combustion chamber) is continually being re-discovered and cleverly demonstrated by marketers who convince themselves there's monetary value in such a bright spark, and all sorts of wild, completely un-provable claims are made for this phenomena.
Like many in the past, Nology cleverly demonstrates a brighter free-air spark containing useless flash-over created by the crude "capacitor" (effect) of this style of wire. In reality, the bright spark has no more useful energy to fire a variable compressed air/fuel mixture than the clean spark you would see in a similar demonstration using any good carbon conductor wire. What is happening in such a demonstration is the coil output is being unnecessarily boosted to additionally supply spark energy that is induced (and wasted) into the grounded braided metal sleeve around the ignition wire's jacket. To test the validity of this statement, ask the demonstrator to disconnect the ground strap and observe just how much energy is sparking to ground.
Claims by Nology of their "HotWires" creating sparks that are "300 times more powerful," reaching temperatures of "100,000 to 150,000 degrees F" (more than enough to melt spark plug electrodes), spark durations of "4 billionths of a second" (spark duration is controlled by the ignition system itself) and currents of "1,000 amperes" magically evolving in "capacitors" allegedly "built-in" to the ignition wires are as ridiculous as the data and the depiction of sparks in photographs used in advertising material and the price asked for these wires! Most stock ignition primaries are regulated to 6 amperes and the most powerful race ignition to no more than 40 amperes at 12,000 RPM.
It is common knowledge amongst automotive electrical engineers that it is unwise to use ignition wires fitted with grounded braided metal sleeves fitted over ignition cable jackets on an automobile engine. This type of ignition wires forces its cable jackets to become an unsuitable dielectric for a crude capacitor (effect) between the conductor and the braided metal sleeves. While the wires function normally when first fitted, the cable jackets soon break down as a dielectric, and progressively more spark energy is induced from the conductors (though the cable jackets) into the grounded metal sleeves, causing the ignition coil to unnecessarily output more energy to fire both the spark plug gaps and the additional energy lost via the braided metal sleeves. Often this situation leads to ignition coil and control unit overload failures. It should be noted that it is dangerous to use these wires if not grounded to the engine, as the grounding straps will be alive with thousands of volts wanting to ground-out to anything (or body) nearby.
Unless you are prepared to accept poorly suppressed ignition wires that fail sooner than any other type of ignition wires and stretch your ignition system to the limit, and have an engine with no electronic management system and/or exhaust emission controls, it's best not to be influenced by the exaggerated claims, and some vested-interest journalists', resellers' and installers' perception an engine has more power after Nology wires are fitted. Often, after replacing deteriorated wires, any new ignition wires make an engine run better."
Modified by Jim Truett at 5:07 AM 9/12/2006
Old Sep 12, 2006 | 10:26 AM
:Andrew's Avatar
i agree i would get ride of those wires i have always had problems with aftermarket ones.
Old Sep 12, 2006 | 07:08 PM
GoldenEGG's Avatar
thanks guys.. NGK blues are on the way.. Hopefully it will get rid of the misfiring.. I will keep you guys posted. Peace
Old Sep 12, 2006 | 09:43 PM
GoldenEGG's Avatar
YES!! fucken almost there.. today i swaped plugs with my brother (oem) , changed my fuel filter, and re-did my ignition timing. Now only one code shows and its 4th Cylinder misfire..
I set my ignition timing on the 14BTC Mark.
What mark did you guys set your timing on?
Old Sep 13, 2006 | 01:10 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: (GoldenEGG)
I believe factory is 16BTC
Old Sep 13, 2006 | 06:56 PM
95IRS's Avatar
your spark plug wires might be hooked up wrong to the distributor
Old Sep 15, 2006 | 10:35 AM
GoldenEGG's Avatar
naw dude my wires are on correct..
So i was driving my Teg the other day... and misfire codes came on again except cylinder 1. Has this ever happend to anyone? Is it because i need my car tuned? Does valves need to be adjusted? or do i have bend valves? I got no idea.. time to just roll this car to the shop
KekeK-18
Mar 29, 2004 05:40 PM
shivic
Jan 4, 2004 04:36 PM
accord94
Apr 17, 2003 06:49 AM
1990hondaHF
25
Sep 28, 2002 06:18 PM
KekeK-18
Oct 19, 2001 08:51 AM
