Engine Rotation Direction Question
I was wondering what direction a b series (specifically a B17) engine rotated. And what direction a 4AG (specifically a 4-AGZE) rotates. Any info would be very helpful.
Re: Engine Rotation Direction Question
ccw on the pulley side.
What about where it goes into the trans... basically I need to know if a b series spins the same way into the trans as a 4ag
No, it does not. Most all engines in cars spin clockwise when viewing the front of the engine (pulley/accessory end), and counter-clockwise when viewing the rear of the engine (transmission end).
Pre-2000 Honda engines are one of the oddballs in the engine world, spinning CCW when looking at the front, CW when looking at the rear. Since 2000, the K-series engine started going into several Honda models, which rotates clockwise like most engines. So the answer is, B-series engines rotate the opposite direction from 4AG (and all other) Toyota engines and transmissions. |
Originally Posted by PatrickGSR94
(Post 38320074)
pretty sure the k series spins cw.
there is a way and i want to figure it out, it has nothing to do with fuel or the motor just timing and starter/adaptor plate. This is not the first time I have seen a b series spin the other direction usually the only problem is finding a tranny to go backwards |
Originally Posted by Transpoquick
(Post 38322757)
Is there any harm in rotating the crank the wrong direction?
Originally Posted by Badweather Jim
(Post 48750710)
| All times are GMT -8. The time now is 09:48 AM. |
