Engine Rebuild. USDM R piston into B18C1
Okay I got the hook up on some new USDM R piston.
The USDM R piston is cheaper than the GSR piston including the ring set prices?? WEIRD??
Will this be an okay fitment into my B18C1 GSR engine since B series parts are the same? I will also be using the same rods.
Thanks.
[Modified by EGB18hatch, 9:40 PM 5/29/2002]
Thanks.
isnt it weird that the R pistons are cheaper from honda. I ordered some, they sent me gsr pistons, i sent them back and got like 60 bucks back.
honestly, i can't tell.
some say it pulls a little harder. but then i installed the typeR flywheel and clutch all at once. also, i don't trust butt dynos.
if you can get them cheap, why not do it? i doubt you get 2-4% increase. you do get some compression though
dustin
dustin
Slick GS-R
Jan 2, 2006 05:51 PM
IdotheSHOCKER
May 29, 2002 01:14 PM
