electrical problems in and ef
Old Feb 22, 2008 | 02:45 PM
aemhernandez's Avatar
Default electrical problems in and ef
i have a ef honda that i just swapped the single cam and put in it a zc engine i did all the wire harness on it but at the time to start the car it didn't turn on i tested the injectors the resistor box and the cables the i changed the computer i put a pr4 but neither it started then i changed the fuel ;pump tha gas relay but the problem keep going on,,,, the tps and the knosk senso are brand new also i tested the distributor but neither too... i think that the car is not receiving enough fuel or if like the spark plugs are not burning the gas .... someona have experienced that kind of problem and give some tip or advised on what to do ???
Old Feb 22, 2008 | 07:52 PM
DAneronimo's Avatar
Default Re: electrical problems in and ef (aemhernandez)
wow, thats confusing.
did you check spark at the plug?
Old Feb 22, 2008 | 08:08 PM
joeyscrx's Avatar
You could have a timing problem. First try and spray some carb cleaner through the throttlebody while someone tries to start it. If it spits and sputters and dies, you have spark. If it doesn't, it's fuel. You probably have a wiring issue in your harness. IDK
apm
15
Feb 18, 2013 03:22 AM
lilvpimp305
Dec 4, 2010 02:46 PM
P1_Variable
22
Mar 1, 2009 05:28 PM
1990civichatchie
Sep 16, 2006 01:39 PM
88 civic ef
Jun 15, 2005 03:00 AM
