ecu plug.. loose wire
ok i searched and found a wire diagram but it didnt match up to what i have for some reason im so confused... ok so i unplugged my ecu and one of the wires wasnt even hooked up it was SOLID BLUE and is the only solid blue wire.. it must not have been hooked up at all cause it just popped out... it says its A5 on the diagram i found but that spot is taken already it is says INJ3 on the diagram... i have a 94 del sol si with a b18c swap... the ecu is a P72 and i dont know which plug the wire came out of either
