ecu fuse blowing
Old Oct 20, 2003 | 11:12 PM
fast+forward's Avatar
Default ecu fuse blowing
like the topic says, FI/ m/ underhood fuse keeps blowing when trying to start. bad ecu? short? or a loose wire grounding out somewhere in the wiring (checked many times over, will continue to check)?
jdm h22 w/ jdm p13 in ek, btw
Any insight is much appreciated
Modified by breakaway at 9:28 AM 10/21/2003
Modified by breakaway at 4:54 PM 10/21/2003
Old Oct 21, 2003 | 12:44 AM
Default Re: ecu fuse blowing (breakaway)
Old Oct 21, 2003 | 06:49 AM
93NXLUDE's Avatar
a friend of mine had a similar prob, the guy that owned it before had a VAFC in it and when he took it out he didn't tape the wired properely.
just a suggestion.
Old Oct 21, 2003 | 08:30 AM
88LXiProject's Avatar
what was the fuse on there, a 7.5amp? 10? could you try a 15 or 20? maybe 20 is too high, but just a suggestion.
Old Oct 21, 2003 | 09:22 AM
green_GSR's Avatar
Default Re: ecu fuse blowing (88LXiProject)
Don't put a fuse higher than what the factory suggest for the ECU. If it keeps blowing, then there must be a short somewhere. Popping in a bigger fuse, you're risking in shorting out the ECU itself.
Old Oct 21, 2003 | 10:56 AM
Default Re: ecu fuse blowing (green_GSR)
yea, i thought about doing that, but that 15 amp fuse is there to protect that ecu...so i guess it looks like time to hunt for a short i used these as my o2 sensor plugs, would they have caused the short?
Old Oct 21, 2003 | 10:58 PM
anybody know why else this fuse would blow? searched far and wide for that shorted wire and couldn't find it...
Old Oct 22, 2003 | 12:57 AM
Old Oct 22, 2003 | 07:56 AM
93NXLUDE's Avatar
Well if you didn't find a short then its PROBABLY in the ecu...if you know someone with the same ecu change them out just to see or you can open yours and make sure something (like a screw) hasn't rolled on or under the circuit board causing it to short out.
Old Oct 22, 2003 | 09:04 AM
96dxB16's Avatar
i bet the injector wire is shorting somewhere. happend to mine once, was shorting on the intake manifold.
Old Oct 22, 2003 | 01:02 PM
Default Re: ecu fuse blowing (96dxB16)
ok, i figured out the problem...i sanded down the areas where my ecu ground was grounded to and changed a couple grounding points in the engine as well as sanding the paint off the surface to where they grounded to and she started right up...
Joshb152
Oct 9, 2015 09:10 PM
NazVil86
Dec 16, 2006 10:41 AM
mazik11
Dec 23, 2005 05:24 PM
terribl3jon
Aug 26, 2004 12:23 PM
SIK IN DA HED
Oct 27, 2002 08:42 PM
