ECU code help...!
Old Aug 16, 2002 | 02:29 PM
jarel's Avatar
Default ECU code help...!
hey all. my brothers 97 prelude sh is having some ecu codes going off. he brought it into the dealer for servicing becuase of some problems with the engine. i was wondering if anyone could help me with some of these ecu codes:
P0108
33-2
43-1
17-1
35-1
hes tried looking for the manual and stuff at the store, but they don't have any for his prelude.
any help would be greatly appreciated. thanks
*he currently has i/h/e, aem cam gears. his car was dyno tune'd at atomic awhile back. currently his cam gears look a little off.
Old Aug 16, 2002 | 02:37 PM
Spade's Avatar
Default Re: ECU code help...! (chyknees)
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
Old Aug 16, 2002 | 02:57 PM
jarel's Avatar
Default Re: ECU code help...! (Spade)
thanks for the help.
im a little new to codes...but on the -1 or -2 marks..what do those stand for?
Old Aug 16, 2002 | 03:00 PM
Spade's Avatar
How is he pulling the codes?
Usually you just jump the ECU and watch the check engine light.
Courtesy of Katman
[Modified by Spade, 4:01 PM 8/16/2002]
Old Aug 16, 2002 | 04:02 PM
88_SC_CRX_Si's Avatar
New User
P0108 - Could mean MAP sensor circuit is receiving to high of a input. The newer ECU's will tell you if a sensor is sending to high of a inputl or too low. In helping with troubleshooting a given sensor.
m00tjam
Jul 21, 2013 02:38 PM
StraightCivic
10
Apr 5, 2006 12:27 PM
lYellowDragonl
Nov 6, 2005 05:20 PM
GreenMachineRex
Dec 24, 2004 04:56 PM
BLuDoHcReX
Apr 3, 2003 07:36 PM
