ECU ???
Old May 6, 2013 | 10:02 AM
bad71chevy's Avatar
Default ECU ???
Im doing a b20b swap on my 94 eg. Im running it OBD1. I have a p06 for it but my question is will a stock p06 ecu give the b20b enough fuel since it came from single cam d series?? Or do i need to get obd1 p75?
Old May 6, 2013 | 10:18 AM
jdmh22eg2's Avatar
Default Re: ECU ???
p06 will start and idle it but I would not suggest driving on it. I would try and find a P75 obd1 if you can or find a socketed obd1 ecu (non vtec) and call phearable.net (vendor here) and get a chip for $35+shipping for your set up
Old May 6, 2013 | 01:01 PM
bad71chevy's Avatar
Default Re: ECU ???
Is a pr4 the same as p75?
Old May 6, 2013 | 01:08 PM
jdmh22eg2's Avatar
Default Re: ECU ???
if i remember correctly the pr4 is obd0 90-91 ls ecu. it would work if you can find a obd1 to obd0 jumper
Old May 6, 2013 | 06:45 PM
bad71chevy's Avatar
Default Re: ECU ???
I also have a socketed p06 without a chip. If i bought a chip from phearable.net would it bypass my sensors too or do you know?
Old May 6, 2013 | 06:54 PM
grumblemarc's Avatar
The Grumpiest
Default Re: ECU ???
If you told them to program it that way then yes. If you dd not then no.
JDMboyEG6
Engine Management and Tuning
Feb 14, 2016 08:28 PM
Ek9_Cuhzz
Northwest (Sales)
Jul 15, 2010 12:07 PM
Jap_Spec_Imports
Aug 10, 2009 07:11 PM
{CHOPZ}
Apr 30, 2009 10:54 AM
