DSM injectors on an h22 for startup?
Old Feb 3, 2006 | 12:05 PM
alleyezonme's Avatar
Default DSM injectors on an h22 for startup?
Alright i just put my car back together from replacing the block. Only prob is it won't startup now. I had it sitting for a while without fuel treatment in the lines (it was in the tank but not the lines. It just hiccups and burps, but won't run. It is a 93 h22.
Ok, so I have a 93 1.8l DSM, i don't know the size of injectors or anything, but I was wondering if i could just slap them in just to try to start it so i know if the reason it won't start is due to clogged injectors. Is this posible? I just don't wanna fork out all that loot for new injectors if that isn't my problem!!
Old Feb 3, 2006 | 05:44 PM
Default Re: DSM injectors on an h22 for startup? (alleyezonme)
back up
Old Feb 3, 2006 | 07:45 PM
airwalk07143's Avatar
is the dsm turboed? then they are 450cc injectors...you can put them in put it is goin to dump to much fuel in at idle... are you sure firing order is right?... if ur sure it is fuel drain the fuel in the tank and add new gas....ive heard of people taking the injectors out and let them soak in injector cleaner over night... good luck
Old Feb 3, 2006 | 08:04 PM
Default Re: DSM injectors on an h22 for startup? (airwalk07143)
yea I drained the fuel and replaced it... I just think it is clogged injectors. All i need them for is just to see if it does anything more then sputter. If it does i know it is b/c of crappy injetors. It is not the turbo... So i am guessing it would run a lil lean... is that ok for the 10 sec. I would use it for???
rice a roni
Engine Management and Tuning
Oct 10, 2015 03:20 PM
crx2hatch
14
Jan 4, 2014 12:34 PM
nus_dogg
May 20, 2012 07:26 PM
DeviousCTR
May 10, 2006 03:31 PM
