Dropping the Motor
Old Apr 11, 2007 | 07:22 PM
LukieLuc's Avatar
Default Dropping the Motor
Does anyone have pics of step by step, instruction to drop a motor out of a car by dropping the frame, cause i dont have an engine lift?
Ps. I have a 1995 honda prelude thanks
Old Apr 12, 2007 | 08:21 AM
LukieLuc's Avatar
Default Re: Dropping the Motor (LukieLuc)
bump for ? above
Old Apr 12, 2007 | 08:46 AM
Crazydave's Avatar
What I did is this:
I took the head off first & removed axles
1.) Disconnect all hoses and electrical connections. and all motor mounts except for the left and right main motor mounts
2.) make a little engine dolley to go under the motor (i used a furniture dolley with a few extra 2x4s for support)
3.) remove jack stands and lower the car/engine onto the dolley just until your see the motor mounts relieve pressure
4.) remove the motor mounts. & make sure the motor doesn't topple over
5.) lift the car up using jack. you many need to put a 4x4x4 piece of wood on the jack to lift it high enough to clear the motor from the engine bay
6.) Pulll the engine out (make sure it doesn't topple)
7.) Put car back on jack stands.
Old Apr 12, 2007 | 11:49 AM
sauceja's Avatar
Default Re: Dropping the Motor (Crazydave)
Or buy a helms and rent/buy a cherry picker.
89ED
Jul 27, 2013 11:44 PM
teg-9
Jul 12, 2011 10:52 PM
Acidcrakker
Oct 8, 2007 04:05 PM
See Are X
Feb 22, 2006 04:45 PM
VTi NA
Jan 28, 2002 02:30 PM
