DOHC ZC fuel injector compatability (Accel)
just picked up a set of new fuel injectors for my '91 JDM DOHC ZC. I was given Accel part no. 151255 "low impedance"
injectors, rated at 255cc/min. These are the listed parts for a D16A6. First off, are these correct for a DOHC ZC? Secondly,
I was told that these injectors are rated slightly higher for flow than stockers; how will this affect my engine performance,
i.e. will they induce a rich running condition? The engine is in a '91 Civic Si, with a short-ram K&N and a header, with a stock
PM7 ecu. The rest is stock.
any feedback appreciated
greg v
greg v
yes, those are the correct ones - unless you had a problem with the stock injectors, the performance won't change - ECU will control the air/fuel ratio based on readings from O2 sensor - the cc/min rating is the maximum output for the injector - if you had several mods and needed more fuel than the stock injectors could supply, you would need larger capacity injectors
jining
Oct 8, 2009 01:53 PM
