Do I need to replace the head gasket?
Old Sep 16, 2004 | 06:32 PM
MatHadder's Avatar
Default Do I need to replace the head gasket?
I just had to pull the head off a jdm d15b today, to replace some bent valves, and I was wondering if the head gasket needed to be replaced. The head gasket was just replaced about a week ago, so i guess my question is whether it will seal ok, or if it needs to be replaced if it has been torqued down. thanks.
Old Sep 16, 2004 | 06:35 PM
acurasolution's Avatar
Default Re: Do I need to replace the head gasket? (MatHadder)
Junk it, if you want to do it right
those gaskets are compressed sealed.
Old Sep 16, 2004 | 08:58 PM
rev-speed's Avatar
why junk something that anit broken?
i use to always junk it
but after one time when i had to pull a head over 4 times to find out why it was smokeing
i have been saveing and reuseing headgaskets
Old Sep 18, 2004 | 08:01 PM
dontfreetibet's Avatar
I would replace it. it will seal a lot better.
Old Sep 18, 2004 | 08:37 PM
porschekremer's Avatar
Default Re: Do I need to replace the head gasket? (waddoups)
i would junk it, its my experiance that its not good to reuse them...
Old Sep 19, 2004 | 11:40 PM
civicsitek GanGsTa's Avatar
Default Re: Do I need to replace the head gasket? (cruisner)
clean it copper spray it and put it back in make sure the mating surfaces are clean to, unless you got HG $$ to burn.
Old Sep 20, 2004 | 07:23 AM
MatHadder's Avatar
Default Re: Do I need to replace the head gasket? (civicsitek GanGsTa)
Yeah, that was my plan. make sure everything is perfectly clean, copper gasket spray, and then reassemble. seems like that should work out ok. if anyone has any horror stories of reusing head gaskets, post them tho.
Cantcatchme
Jan 5, 2012 03:26 PM
da_33
Jan 11, 2007 11:12 AM
mulin
Nov 3, 2004 09:25 PM
Layziebtnh055
Jun 3, 2004 08:05 PM
rathead
Jul 29, 2003 04:39 PM
