Distributor - Inner Seal Replacement
Old Dec 2, 2013 | 01:09 PM
1stump's Avatar
Default Distributor - Inner Seal Replacement
Hello all,
OK, this might be a stupid question but I can't find an answer. I just replaced my distributor's inner and outer seals on my 98 Accord. The DIYs I've seen say to put the inner seal in dry. I used a little 30W engine oil to make it easier to go in. Is that oil going to deteriorate the seal? Sorry, It's the **** personality in me!
Thanks for any input,
Stump
Old Dec 2, 2013 | 08:22 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Distributor - Inner Seal Replacement
No.
Old Dec 3, 2013 | 07:23 AM
1stump's Avatar
Originally Posted by DCFIVER
No.
Great. Thanks a lot for your time DCFIVER.
Old Dec 3, 2013 | 01:38 PM
slowcivic2k's Avatar
Never install any seal without at least some lubrication, or else the seal may burn and leak soon afterwards.
For seals like that use a SMALL amount of grease on the lip cavity and lightly coat the shaft as well.
Old Dec 3, 2013 | 02:22 PM
1stump's Avatar
Perfect. Thanks for your input slowcivic2k.
Old Dec 3, 2013 | 11:23 PM
holmesnmanny's Avatar
Just to elaborate further, he means on the inside lip only. The outside part of the seal is never going to move so you don't need to lubricate it and you want it to be dry anyhow to prevent any oil from ever pushing past it. The inside lip has a spring on the inside that helps push against the inner lip which helps to prevent oil from going past it, the outside doesn't.
You want grease on the inner lip to help the inner lip to break in properly.
If it's installed completely dry, then when the seal first starts to turn it could bind and tear, causing it to leak.
Old Dec 4, 2013 | 04:19 AM
1stump's Avatar
Thanks holmesnmanny. I did put lubricate on the outside. I'll be checking the cap for any oil in the next day or so. I'm now glad that I asked. This bit of detail will help others. Thanks again.
gixxerboy750
Aug 7, 2010 11:37 AM
k_lude
Feb 9, 2009 08:00 PM
teambk8
Nov 2, 2008 01:47 AM
garyc17
May 2, 2008 03:31 AM
kbud
Feb 2, 2008 01:52 PM
