del sol rear tranny mount
I have searched and i know i need a rear tranny bracket from a 99 si to put my b16 into my 96 hb. but i have a 95 del sol rear tranny bracket and it bolts up to the block just fine..will this bolt to the frame? its a del sol vtec and the junkyard guy said it would fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4cylinder »</TD></TR><TR><TD CLASS="quote">it call a L-braket
u will need a gsr one
a b16 is too long</TD></TR></TABLE>
Don't offer advice about mounts ever again
the Del Sol VTEC rear mount bracket is IDENTICAL to any 94-01 integra bracket
there is a lot of misconception about mounts.....here is what is the same
Civic manual tranny mount is IDENTICAL to any 94-01 integra tranny mount (the civic mount has an extra peice that is just bolted on, just remove that piece and you are good to go)
Rear mounts are the same on 92-00 civic and 94-01 integra
and for drivers side upper the 3-hole mounts are all identical and the 2hole mounts off of a 90-93 integra will work in an EG or DC chassis with the correct bracket on the block
if you have any more questions about mounts feel free to ask
hotimportcrx
Oct 23, 2005 03:37 PM
Sliced Beard
Mar 26, 2004 02:36 AM
