Del Sol radiator with B18B1 questions
Old Aug 2, 2002 | 02:06 PM
Civic1992DX's Avatar
Default Del Sol radiator with B18B1 questions
Does anybody have overheating problems with Del Sol double core radiator on B18B1 engine? Today when driving in 97F heat my Water Temp gauge showed 235F (I was driving 80-90mph). Water pump has 15k miles on, thermostat is new, no A/C. Usually it gets up to 220F when driving like that but today it was weird...
Should I upgrade to Integra radiator or Del Sol is adequate?
What water temp. are you guys running in this hot summer?
Thanx!
Yuri K
[Modified by Civic1992DX, 11:07 PM 8/2/2002]
Old Aug 2, 2002 | 08:46 PM
Default Re: Del Sol radiator with B18B1 questions (Civic1992DX)
anyone? I was sweating my A** today, driving to school with heater on FULL blast in 97F degree heat...
Help me out please...
Yuri K
Old Aug 2, 2002 | 09:42 PM
ionic_slim's Avatar
check to see if the cooling fan comes on. run wires from your battery directly to calling fan to see if it works.
Old Aug 3, 2002 | 09:33 AM
IlikeTODA's Avatar
Default Re: Del Sol radiator with B18B1 questions (tazmoe)
Should be fine, but do like he said and maybe check your thermostat and see if its opening.
Thanks, J
Old Aug 3, 2002 | 10:49 AM
Default Re: Del Sol radiator with B18B1 questions (IlikeTODA)
fan turns on just fine. Remember, the temperature got that hot ONLY while driving 80+ mph. @ that speed you don't need the fan because the volume of the air rushed through the radiator is so much more than the fan can blow through.
Jorge4g63
Nov 19, 2013 06:57 PM
powersk8er92
Jun 30, 2012 08:36 AM
yamaha6611
Oct 7, 2010 07:35 PM
solsrt9305
12
Oct 3, 2007 03:41 PM
hopware
May 14, 2006 01:26 PM
