degreeing your camshafts
Old Sep 12, 2004 | 12:36 AM
mrfi's Avatar
Default degreeing your camshafts
I have the pro degree kit and had a few questions.
how do you set 'zero' valve lash? set it to the manufacture's lash rating or at a different rating?
where exactly does the dial indicator go? on the retainer? camshaft lobe? does anyone have a picture to help me out here?
i understand the process is done, i am just a little unsure about the zero valve-lash and indicator positioning.
Old Sep 13, 2004 | 05:25 AM
JimBlake's Avatar
Default Re: degreeing your camshafts (mrfi)
Are you sure you're not confusing valve lash vs. valve timing adjustments?
I don't know that kit, so maybe explain your question some more.
Old Sep 13, 2004 | 03:21 PM
stumpyf4's Avatar
The indicator goes on the retainer.
Put the indicator on the retainer and then adjust the valve lash (clearance) to zero (no clearance between the rocker and the cam). You'll know it's close to zero as soon as the indicator starts moving.
ratchetEDsedan
10
Feb 27, 2017 07:32 PM
totsie7944
Feb 22, 2009 01:49 PM
mrfi2
Sep 12, 2004 05:30 PM
