DC2 rear seat Help!
Old Jun 11, 2010 | 09:48 AM
S2Integra's Avatar
Default DC2 rear seat Help!
I tried to search this topic, but couldn't really find what I was looking for. I want to remove the rear seat for a dc2. I had no problems with the db8 chassis, but i cannot see any thing for the DC2. I mean I see only one 10mm bolt, and it doesn't even look like it holds the seat down. What am I missing here? I am in the middle of battery relocation and 2 other projects, so any help would be appreciated.
Old Jun 11, 2010 | 09:54 AM
S2Integra's Avatar
Default Re: DC2 rear seat Help!
do I have to completely remove the side panel? I ain't seeing nothin otherwise
Old Jun 11, 2010 | 10:05 AM
S2Integra's Avatar
I check back later
Old Jun 11, 2010 | 10:08 AM
ekedc2's Avatar
took the 10mm bolt out and on the panel side theres a black ring you have to remove so you can move the seat to the side to remove the upper part.
Old Jun 11, 2010 | 10:29 AM
S2Integra's Avatar
Okay, I also found the loop and took th bolt off that, but something is holding it down the the front on both sides. Can't see what it is so I guess itt remove the carpet. I'll figure it out, but I do see what you mean so I'll do that first.
Old Jun 11, 2010 | 01:17 PM
Trk2112's Avatar
theres one bolt on the bottom part kinda in the center on the back then lift from the back and swing it foward, theres 2 hooks on the front
Old Jun 12, 2010 | 01:15 AM
TheAsian's Avatar
Yea 10mm on back then pull straight up on the fron. It comes right out. May need a little force on the front. I can have the rears out of my teg in about 2 min
BrayzieEF9
Jan 6, 2010 08:17 AM
1hotintegra
Acura TL, RL & ZDX
Apr 14, 2005 02:13 AM
sunsetway
Jun 7, 2003 11:19 AM
USDMMARK
Jan 29, 2003 03:24 PM
94RS
Sep 7, 2002 03:35 PM
