d-series throttle bodies
A few questions I am having trouble researching
What can actually fail within the throttle body? I'm not talking about actual sensors, I mean the actual TB. The reason I am asking is that I have a d-series throttle body I am attempting to repair.
Is it bad that underneath the tps is rusty and corroded, I cleaned it out the best I could with brake cleaner and a toothbrush, but idk if there is anything that could fail in there.
Is the MAP sensor necessary for functional operation? I have one on my TB but it has never been plugged in, I don't even see wires for it anywhere near there. I am on a crome eprom tune if that is relevant.
Thanks
Thanks
Throttle shaft bearings
Throttle plate screws
Throttle arm
Yes, unless you're running Alpha-N (TPS-based load). But based on context , I'm presuming you're not. It may be relocated.
Edit: looks like a megasquirt/megatune thing? I dont have megasquirt for sure. Does that mean I am just failing to locate a MAP sensor on the firewall?
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/bad-idle-stalling-d16z6-also-firewall-vs-tb-mounted-map-sensor-3068446/
I also had a CEL 7 and issues with dying under load and stalling at low rpm
Thanks for your help!
Alpha-N is a universal term, not specific to any brand of management. It just means the ECU is not referencing manifold vacuum/pressure (MAP) to determine load. On a Alpha-N tune, throttle posistion is the only load reference. It's most common on applications where vacuum signals are either too weak or erratic to use a MAP sensor.
If that's the case, they certainly had a 3+bar MAP sensor somewhere. You wouldn't want to run 28psi of boost with TPS for load - there too much transient variation between 25" of vacuum and 28 psi of boost. It's hard to tell you what to look for because there could be a GM 3-bar tie-wrapped to something, or a AEM/SST 3,4,5 bar tee'd off the manifold... i have no idea. How are the columns in your crome tune labeled?
The hunt for the missing map sensor continues. lol
I replaced the TPS, calibrated it, replaced the cap and rotor, spark plugs, cleaned off all of my grounds, and made sure the EPROM chip was all the way plugged it. It seems to be running great now, but the MAP sensor still has me worried
I dont have any of the tuning stuff for crome, it was all done by the PO, I haven't ever even had a chance to look at it. I would need a $100 chip interface for that?
Updated with engine bay pics, guy seems to think i must have a firewall mounted MAP
https://honda-tech.com/forums/showth...1#post47564321
ATrin
Dec 10, 2005 01:25 PM
