cx wiring harness for a b16a question???HELP
Old Sep 2, 2002 | 12:02 AM
stockegsix's Avatar
Default cx wiring harness for a b16a question???HELP
Help, i'm getting cel code 41(o2), i have a 92 cx with a 2nd gen b16a w/ p28 ericks racing ecu. i'm using my stock harness and i notice that theres only 1 wire for the o2. how do i fix that? thanks
1) if i use a ex/si 5th gen civic harness, will it fit?
2) is there a way i can connect a 4 wire o2 sensor to the cx harness?
3) will CEL 41 affect my cars performance?
Old Sep 2, 2002 | 02:42 AM
BigBlockCRX's Avatar
New User
Default Re: cx wiring harness for a b16a question???HELP (silversleeper)
1 wire o2 sensor? you need the 4 wire o2 sensor
Old Sep 2, 2002 | 10:58 AM
salbaje's Avatar
use a dx harness or ex. if you need it i have it. but you can also hardwire the 1 wire o2 if you want
Old Sep 2, 2002 | 11:30 PM
BoredNStroked's Avatar
Default Re: cx wiring harness for a b16a question???HELP (salbaje)
Just add the needed pins to the ecu harness and connect them to a four wire o2......
Old Sep 3, 2002 | 12:28 AM
stockegsix's Avatar
Default Re: cx wiring harness for a b16a question???HELP (BoredNStroked)
how do you add the wires to the harness?? any diagrams
Old Sep 3, 2002 | 08:23 AM
advanracing62's Avatar
I went to the salvage yard and pulled an O2 sensor plug from an Accord, as they use 4 wire O2 sensors. Then I wired that baby up to my harness and all was well in emissions land, well except that I can't seem to pass emissions. HTH!!
killerb7888
10
Oct 29, 2013 07:47 AM
johnxjohn26
Apr 22, 2007 08:07 PM
_gurusan_
Aug 2, 2006 05:59 PM
P_dizzle24
Jul 31, 2006 09:03 AM
DevineCRX
Jul 18, 2002 07:31 AM
