CTR camshaft specs - open/close degrees
Old Oct 8, 2002 | 06:54 PM
IN VTEC's Avatar
Default CTR camshaft specs - open/close degrees
Taken from the Hybrid Honda site.
Intake
(VTEC lobe)
open 18° before TDC
close 45° after BDC
valve lift 11.5mm
Exhaust
(VTEC lobe)
open 45° before BDC
close 10° after TDC
valve lift 10.5 mm
How accurate is this info? I need the info to be accurate so I can degree the cams in.
Old Oct 8, 2002 | 07:08 PM
Kinmar_X's Avatar
Default Re: CTR camshaft specs - open/close degrees (IN VTEC)
Cams Measured at 1mm of lift:
Civic Type-R And Integra Type-R(Integra Type R 2000/01 Spec)
Int-243 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
not sure if that helps any but...
Lift seems right not sure about open/close °'s though
Old Oct 8, 2002 | 11:25 PM
IN VTEC's Avatar
Default Re: CTR camshaft specs - open/close degrees (Kinmar_X)
The total amount of duration correspond for both sets of numbers...so yeah....I guess I can assume that the numbers will work.
jdm ek9 101
Jul 26, 2006 05:57 AM
ziich2
Feb 7, 2006 07:44 AM
AK94GSR
Dec 24, 2004 05:58 PM
Michael Delaney
Dec 23, 2002 07:19 PM
markaria
Sep 27, 2001 08:37 AM
