CRX /w Walbro intank, Bosch 044 Inline PROBLEMS! HELP!
Old Apr 16, 2010 | 12:16 AM
Aladar's Avatar
Default CRX /w Walbro intank, Bosch 044 Inline PROBLEMS! HELP!
So, i got a bosch 044 inline kit before the rail to see more power out of my setup. So, when i hooked it up to power i looked at the guage on the fuel rail, and the FP jumped up to about 62 base. So, i figure it was working obviously. After i let the car idle to see if i had any problems, i looked at the guage again, and i see the needle jumping from 50-62 psi ERRATICALLY. Like a rabbit on crack. just back and forth. and it wont stabilize at all.
Im wondering what could be the problem, i have steady voltage on the pump, cause i thought it could be that. So any ideas? suggestions? Thank you
Old Apr 17, 2010 | 09:37 PM
kte324's Avatar
Default Re: CRX /w Walbro intank, Bosch 044 Inline PROBLEMS! HELP!
I have seen a problem like that, it turned out to be the regulator.
Old May 3, 2010 | 05:14 PM
thegreen's Avatar
Some of the old Audi & VW's with high fuel pressure run a damper, that softens the pulses. Think it's called a pressure accumulator.. Good luck!
b16hatche
Nov 11, 2005 06:28 PM
RedRocketCRX
Aug 23, 2004 01:50 PM
SLOAZZ95
Aug 5, 2004 04:29 AM
Andrew 825SM
Nov 17, 2002 01:42 AM
HX_Guy
Jan 29, 2002 07:32 AM
