CRX HF B18a1 Code 13
Old May 9, 2013 | 07:57 AM
Phillybiker's Avatar
Default CRX HF B18a1 Code 13
Newly swapped 91 Crx HF with a 95 B18a1 running an Acura Integra LS GS B18 ECU PR4 90-91 Engine Computer.
Runs good besides throwing a 13 code right away. (One long bling followed by three quick ones.)
I've started the motor on a 89 integra ecu and it threw the same code.
Im running an obd-0 distributor that doesnt have the same bolt pattern as this engine. I'm in the process of getting the correct one. Only the one top bolt on the dizzy lines up. Not sure if that has any difference. I'm hoping I get this 90-91 integra distributor and have this code 13 problem go away we will see.
What is the most likely problem?
kevcha711
Feb 5, 2010 07:32 PM
stivic
21
Aug 27, 2009 04:37 PM
hatchyboy89
Oct 11, 2007 10:48 AM
89civichatchback
Feb 26, 2005 03:44 PM
pdiddyparsons
Apr 16, 2003 07:07 PM
