Coverting B18a1 to Obd1?
Old Jan 21, 2006 | 03:08 PM
91dxcrx's Avatar
Default Coverting B18a1 to Obd1?
What all do I need to convert a B18a1 to Obd1 besides an Obd1 dizzy and ecu?
Old Jan 21, 2006 | 11:34 PM
hapexamendios 2.0's Avatar
R.I.P.
Default Re: Coverting B18a1 to Obd1? (91dxcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91dxcrx &raquo;</TD></TR><TR><TD CLASS="quote">What all do I need to convert a B18a1 to Obd1 besides an Obd1 dizzy and ecu? </TD></TR></TABLE>injectors maybe?
Old Jan 22, 2006 | 12:56 AM
Katman's Avatar
This depends on what you're doing.
If you're converting a B18A1 in a 90-91 integra over to OBD1 you need these parts:
- OBD-&gt;OBD1 jumper harness converter & OBD1 ecu
- OBD1 injectors is optional, you can actually keep using the OBD-0 injectors, just remove the resistor box and perform a small wire mod related to the resistor box.
- an OBD1 4-wire 02 sensor
If you're just converting the engine itself outside of the vehicle, you'll need these parts:
OBD1 wire harness
OBD1 injectors
OBD1 dizzy
OBD1 ECU
possibly a 94-01 integra throttlebody (with top mounted MAP sensor).
Old Jan 22, 2006 | 09:27 AM
91dxcrx's Avatar
Default Re: Coverting B18a1 to Obd1? (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">This depends on what you're doing.
OBD1 wire harness
OBD1 injectors
OBD1 dizzy
OBD1 ECU
possibly a 94-01 integra throttlebody (with top mounted MAP sensor).</TD></TR></TABLE>
The B18a is going into my Crx. So I'll need the dizzy, injectors, throttlebody, obd1 ecu and conversion harness. Correct? I won't need an o2 sensor because I'll be running open loop for boost. Thanks for the help
Dkahn18
Feb 18, 2009 04:41 PM
crxdummy
Mar 22, 2007 02:57 PM
dayton_crx
Jan 30, 2007 01:58 PM
aVstAr
Dec 26, 2003 07:41 PM
skud_dusty
13
Apr 25, 2003 11:51 PM
