The CORRECT S1/J1 gear ratios
Old Nov 2, 2004 | 07:46 PM
Runnerdown's Avatar
Default The CORRECT S1/J1 gear ratios
According to allmotorhonda.com and several others, the jdm S1 and J1 both have this for gear ratios:
1st 3.30
2nd 2.10
3rd 1.45
4th 1.10
5th .84
4.40 final
Now according to a J1 I have and a S1 my friend has they are the following:
1st 3.25
2nd 2.05
3rd 1.41
4th 1.10
5th .90
final 4.40
Not a huge difference but it had me confused for a bit. The only site I found that was correct was http://www.autocrossing.com/cgi-bin/gearcalc.cgi
Old Apr 16, 2013 | 06:50 PM
Boothef's Avatar
Default Re: The CORRECT S1/J1 gear ratios
yes this is correct , I just got done rebuilding my J1 , when I did my rebuild on the J1 Tranny my gear ratios where the same as above ,
also out of curiosity I removed the housing case of one of my old 1990-1991 USDM S1 transmissions to compare.
my results are below
JDM 1988-1991 J1 cable small spline Transmission results:
teeth count
main/counter:
1rst: 12/39 ratio= 3.25
2nd: 19/39 ratio= 2.052
3rd: 24/34 ratio= 1.416
4th: 29/32 ratio= 1.103
5th: 32/29 ratio= .0906
final: 15/66 ratio= 4.4
diff ring: 66
and might as well post my - 1990-1991 USDM S1 cable small spline results :
teeth count
main/counter:
1rst: 12/38 ratio= 3.166
2nd: 21/39 ratio= 1.857
3rd: 27/34 ratio= 1.259
4th: 31/29 ratio= 0.935
5th: 35/26 ratio= 0.742
diff ring:66
one thing that all 1990-1991 tranny's and maybe the 1992-1993's have is that unlike the HORRIBLE 1994 and up LS transmissions with the 4.26 final ratio with the 64 teeth ring gear (differential gear)
The 1990-1993 I believe all come with a 66 tooth ring gear (differential gear)which equals the 4.4 final ratio
Rickvanuden
Transmission & Drivetrain
Jun 8, 2017 09:00 AM
gray_civic_coupe
Sep 16, 2005 01:15 PM
Jared
Mar 15, 2003 02:18 PM
