Coolant overflows when parked... car doesn't run hot.
This one is weird. I could understand my coolant overflowing if the car were running hot, but it DOES NOT RUN HOT. I can drive the car and park it and then when I come out I'll have a puddle of coolant under the car. I can get in and drive it and everything is fine, it doesn't do it every day either. After about the thrid time the car will start to run hot, I add coolant the cycle starts over again.
Sometimes it "gurgles" when I shut the car off too, the problems don't happen consitently!
I'm thinking I need a new radiator cap. Suggestions? Comments?
why don't u see where it's leaking from before you go out and buy another cap? have u examined the radiator and all its hoses to check for leaks?
hmm, could very well be the radiator cap. there's no oil or anything except coolant in the resevoir rite? i don't think it'd be a blown head gasket, since you're not billowing out white clouds of smoke. try getting a new cap and see what happens.
Oscar Ponce
Feb 26, 2012 11:15 PM
Razr2
11
Jan 19, 2008 12:50 PM
