Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   compression problems (https://honda-tech.com/forums/tech-misc-15/compression-problems-183821/)
mick May 12, 2002 12:17 AM
a few months ago i noticed a sudden lack of power in my teg, got a compression test done and got 120/180/180/180 (120 in cylinder 1); leakdown test concluded the same, somethings broken.
we've just removed the head on my b16a1 this arvo, had a look at the head gasket, and it seems to be fine; anything else that could be wrong? (whats the likelyhood that it could be piston rings?)
cheers, michael
Prelude Vtec 23 May 12, 2002 04:11 AM
Re: compression problems (mick)
You could have bent valves, have you checked that??
mick May 13, 2002 02:14 PM
Re: compression problems (Prelude Vtec 23)
nope - ill have a look!
anything else that may be wrong? warped head?
Chiovnidca May 13, 2002 04:35 PM
A leakdown test works pretty good for narrowing down low compresion problems. http://images.zeroforum.com/smile/emsmile.gif
Doogie Howser May 13, 2002 06:39 PM
Re: compression problems (Teken)
id say rings
mick May 13, 2002 11:31 PM
yeah - when i had the car running lots of air came out the oil filler cap - what would this indicate?
no - i didnt try putting some oil down the cylinder when doing the compression test, will try that though when i get it back together, thanks for the tip!
when i had the leakdown test done it indicated cylinder 1 was 10% loss, the rest were 5%.. with bubbles comin out the radiator cap, so one would assume the gasket? (however this doesn't seem to be the case); any other ideas?
much appreciated, cheers
[Modified by mick, 8:34 AM 5/14/2002]
Chiovnidca May 14, 2002 09:48 AM
Air bubbles in the cooling system during a leakdown test indicate a bad head gasket, a cracked head or a cracked cylinder.
[Modified by Chiovnidca, 9:36 PM 5/14/2002]
Lyonel May 14, 2002 06:03 PM
Hey Teken!
Here are some pics when we removed the head from Mick's DA6.
http://homepages.paradise.net.nz/asm...s/P0003512.jpg
http://homepages.paradise.net.nz/asm...s/P0003513.jpg
http://homepages.paradise.net.nz/asm...s/P0003514.jpg
http://homepages.paradise.net.nz/asm...s/P0003515.jpg
http://homepages.paradise.net.nz/asm...s/P0003516.jpg
http://homepages.paradise.net.nz/asm...s/P0003517.jpg
mick May 17, 2002 07:55 AM
im starting to wonder whether the problem is actually in the block, though it wasn't putting out any noticeable black/blue smoke..
going to get it pressure tested/check out the value seats in cylinder 1 next thurs, i'll soon find out whether its the head or the block i suppose..
thanks for all your input guys, much appreciated http://images.zeroforum.com/smile/emsmile.gif
mick May 19, 2002 12:26 AM
teken: yeah man, stock headers suck ass http://images.zeroforum.com/smile/emsmile.gif
mick May 23, 2002 02:09 AM
right, got the head pressure tested/leak tested today, and it turned out fine!! valve seats are fine.. so im erring more on the side that the head was warped due to overheating? (problem is this isnt consistent with the condition of the head gasket (which was fine, no scorching or anything))
LSyellowREX May 23, 2002 02:26 AM
the only way i can think of a warping head is by pooring water on it after its been run hard... my guess is that you have a cracked cylinder or your #1 cylinder ring isnt sealing combustion properly... check both of those...
mick May 26, 2002 08:44 PM
Re: compression problems (LSyellowREX)
yip! gonna check rings in cylinder 1 tomorrow.. ill keep you posted!
mick May 28, 2002 03:38 PM
got piston 1 out, and the rings are fine!!!!!!!!
so im stumped.. anyone got any ideas? the head wasnt majorly warped, valves are seated properly, the rings in the cylinder that was down are fine.. only other thing i can think of is a warped block, but this seems unlikely since the head wasnt warped..
confused!
mick Jun 7, 2002 07:43 AM
Re: compression problems (EVIL Teken)
got it all together again, gonna get a compression test done soon - will let u know of results, it seems better so im hopin for the best..
