Code will not go away! TPS and O2's
Old Feb 10, 2004 | 05:16 PM
ICeDoUt's Avatar
Default Code will not go away! TPS and O2's
I got a code that will absolutly not go away. It was a code 7 and code 1. I got 2 new (bosch universal) O2 sensors, put them in still got both codes. Then i got a new to me but used tps, and set it exactly to .45 at idle and still get the code. I reset my ecu like 10 times already. There are other people in here that have the same problem but the question was never answered in the crx forum, so any help from the tech guys??? The motor is a Jdm b16a1. (its one long blink, O2, then seven short, tps)
Old Feb 10, 2004 | 05:35 PM
alleyezonme's Avatar
Default Re: Code will not go away! TPS and O2's (ICeDoUt)
bump for a palm loser
Old Feb 10, 2004 | 05:42 PM
hondatim's Avatar
Default Re: Code will not go away! TPS and O2's (bumpincivic20)
are you sure it's not a code 17 for VSS (vehicle speed sensor) and not a code 1, and code 7.
could you mistakenly be reading flashes wrong. Not trying to flame, just asking.
Old Feb 10, 2004 | 05:48 PM
ICeDoUt's Avatar
Default Re: Code will not go away! TPS and O2's (hondatim)
vss, is electric, i converted it so i cna use a gsr cluster. My tach and speedo work perfectly, i don't see why it would have to deal with that. And if it did, why is my speedo still working?
Old Feb 11, 2004 | 03:52 AM
ICeDoUt's Avatar
anyone else?
Old Feb 11, 2004 | 08:30 AM
Smith Wise's Avatar
Default Re: (ICeDoUt)
get a denso or oem sensor...
if that doesn't work, then it's a wiring issue....
unplug the VSS and see if you get any more codes.... that will let you know whether you're reading it correctly or not....
Old Feb 11, 2004 | 09:36 AM
EE_Chris's Avatar
Default Re: (Jswpstdoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jswpstdoff &raquo;</TD></TR><TR><TD CLASS="quote">Unplug the VSS and see if you get any more codes.... that will let you know whether you're reading it correctly or not....</TD></TR></TABLE>
Sounds pretty logical to me....or unplug the TPS/O2 to achieve the same thing.
Old Feb 12, 2004 | 01:43 PM
Big Bang's Avatar
when you ran the new wire to the vss did you just hook it up to the cluster or did you attatch it to the one that goes to the ecu too?
Old Feb 14, 2004 | 10:09 PM
ICeDoUt's Avatar
Default Re: Code will not go away! TPS and O2's (The Converted)
i didn't run it to the ecu, i just ran it to teh cluster, should i run it to the ecu also?
Old Feb 15, 2004 | 12:33 PM
ICeDoUt's Avatar
yea problem fixed, my dumb *** was reading the code wrong, it was the VSS i had to run a wire from the signal from the vss to b6 (i think) in my ecu, thanks for the suggestions, it helped me out!
O RLY
Jul 6, 2010 02:06 PM
hatch96y7
Nov 19, 2007 10:58 AM
scarface50370
Dec 14, 2005 01:21 AM
