clutch or tranny issue?
Old Oct 5, 2005 | 11:58 AM
racekar's Avatar
Default clutch or tranny issue?
95 gsr
the gears all go in fine and no grinding.
when in gear if i let off the throttle and cruise in gear sounds like a metallic grinding noise like its coming from the brake but its not. and if i hit the throttle again the noise goes away when i shift into neutral it goes away only when in gear worse in 1-3 gear.
also as i let off the clutch when switching gears it feels like the clutch is grabbing hard not smoothe as a stock car would.
changed the fluid didnt make a difference not sure if its bearing or the tranny.
the clutch grabs fine also, any ideas
jrhcivak
17
Apr 11, 2012 03:55 PM
Groove_D
Oct 14, 2004 06:59 PM
Jason C SBB
18
Feb 22, 2004 11:37 PM
Jeff C
Jun 20, 2003 03:43 PM
